Question: Round-off and simple triggers
 Can anyone explain me how to use the next feature that you can find in ?dsolve,numeric,events,Round-off and simple triggers or refer me to a previous answer that explain this:
   This is primarily desired to be able to apply events for an ODE system that has been separated into disjoint cases dependent on the values of particular triggers (in which case you always want to use a form that provides the values just past the trigger point).
 Specially how to separate the ODE system into disjoint cases. Thanks in advanced.
