Question: Problem with integral
After manually working out answer for problem 4-4 in Mathews & Walker's Mathematical Methods of Physics , I tried to check my solution with maple2015. Briefly the problem involves inputs periodic with period T, being transformed into outputs, through a kernal G.  The net result is that all input frequencies omega periodic in T are multiplied by (omega_0/omega)^2, except for constant frequency which transforms to zero.  The problem asks to evaluate the kernal G.
Maple2015 correctly evaluated the integral for a constant input, a cosine input, and a sine input, but gave undefined when I tried an exponential(i*x) input which is just a linear combination of the two previous inputs.  I found this interesting because the integral is finite, well defined, and only has an absolute function (in the kernal), which may cause Maple problems, as it correctly evaluated integral when I split it into two regions.  Interestingly if instead of working with a period of T, I used 2*pi, and redfined my G function accordingly, Maple evaluated the exp input integral without any problems.  So the problem appears to be with the T variable, but I correctly used assumptions of T>0, and 0<t<T, so I am not sure why it would work correctly when I use T=2*pi, but failed when using a general period T.  Any help would be welcome.
restart
assume(T > 0)
assume(0 < t and t < T)
about(T)
Originally T, renamed T~:
  Involved in the following expressions with properties
    T-t assumed RealRange(Open(0),infinity)
  is assumed to be: real
  also used in the following assumed objects
  [T-t] assumed RealRange(Open(0),infinity)
about(t)
Originally t, renamed t~:
  is assumed to be: RealRange(Open(0),infinity)
assume(n::integer, n > 0)
about(n)
Originally n, renamed n~:
  is assumed to be: AndProp(integer,RealRange(1,infinity))
G := proc (x) options operator, arrow; (1/2)*omega0^2*T^2*((1/6)*Pi^2-(1/2)*Pi*abs(2*Pi*x/T)+Pi^2*x^2/T^2)/Pi^2 end proc
(int(G(t-tp), tp = 0 .. T))/T
0
(int(G(t-tp)*sin(2*Pi*n*tp/T), tp = 0 .. T))/T
(1/2)*T^2*omega0^2*cos(t*Pi*n/T)*sin(t*Pi*n/T)/(Pi^2*n^2)
(3)
(int(G(t-tp)*cos(2*Pi*n*tp/T), tp = 0 .. T))/T
(1/4)*T^2*omega0^2*(2*cos(t*Pi*n/T)^2-1)/(Pi^2*n^2)
(4)
(int(G(t-tp)*exp((I*2)*Pi*n*tp/T), tp = 0 .. T))/T
undefined/T
(5)
(int(G(t-tp)*(cos(2*Pi*n*tp/T)+I*sin(2*Pi*n*tp/T)), tp = 0 .. T))/T
undefined/T
(6)
simplify((int(G(t-tp)*exp((I*2)*Pi*n*tp/T), tp = 0 .. t))/T+(int(G(t-tp)*exp((I*2)*Pi*n*tp/T), tp = t .. T))/T)
(1/4)*omega0^2*exp((2*I)*t*Pi*n/T)*T^2/(Pi^2*n^2)
(7)
assume(0 < t and t < 2*Pi)
G2 := proc (x) options operator, arrow; 2*omega0^2*((1/6)*Pi^2-(1/2)*Pi*abs(x)+(1/4)*x^2) end proc
(8)
(int(G2(t-tp)*exp(I*n*tp), tp = 0 .. 2*Pi))/(2*Pi)
omega0^2*exp(I*n*t)/n^2
(9)
Download MathewsWalkerProblem4-4.mwMathewsWalkerProblem4-4.mw
