Question: Complicated question
Good Morning,
This is the script that I have used to to an integration, as the command ''int'' didn't work because the coputation was really heavy.
p_old := 0;
g := 0; #index
E_tot_net_Point := 0;
for g to 2 do
 h := g+1;
 loopstart := SP_time[g];
 loopend := SP_time[h];
  for tt from loopstart by 0.01 to loopend do
   t := tt;
   P_tot_net_Fkt := t -> C_motore[g]*omega_motore[g]
if t≠SP_time[g] and t ≠ SP_time[h] then
 P_tot_net_Point := P_tot_net_Fkt(t);
 P_tot_net_Point_next := P_tot_net_Fkt(t+0.001);
 plt_P_tot_net_plt[t] := pointplot([t, P_tot_net_Point]);
 E_tot_net_Point := E_tot_net_Point+(P_tot_net_Point*0.01);
 plt_E_tot_net_plt[t] := pointplot([t, E_tot_net_Point]);
 p_old := P_tot_net_Point;
end if;
  end do:
end do:
plots:-display(entries(plt_E_tot_net_plt, 'nolist'), title = "Energy", color = "Red", symbol = point, symbolsize = 20, gridlines = true, size = [1000, 500], labels = ['[s]', '[Watt*s]'], font = [axes, 12])
I have plotted the function as a series of points over the orizontal axis (t).
Now I would like to calculate the last value of the curve (which is itself a point) as a function of the orizontal axes t. How can I do it?
Something like E_tot_net_Point = f(t)
Thank you for the help
