Question: Error in dsolve/numeric
I'm sorry to bother you but I have a problem with the numeric resolution of a system of 3 differential equations. The system is as follows  : sysdif :=
As you can see the system is composed of 3 differential equations, and I enter initial conditions in the object "sysd". Then I try a numeric resolution by executing the following command (I give a value to parameters before)  :
Then Maple's answer is : Error, (in dsolve/numeric/process_input) missing differential equations and initial or boundary conditions in the first argument: sysdif.
I can't see where I'm wrong, does anyone notice something that could explain this error message ? There's no help page about this error so I ask the question here.
Thank you very much for your time if you answer this,
Louis
