Question: Having trouble with print
Hi, I'm having trouble with print doing strange things:
a:=1235
                1235
b:=751
                751
p:=1601
                1601
print(The solution `to` a^x = b (`mod ` p) is x = 1323)
                              1601 The solution to (1235^x) = 751 mod is x = 1323
Why has the 1601 gone to the beginning, and how do I make it go to the correct place?
Also is it possible to remove the brackets from around 1235^x?
And is it possible to make the brackets (that I have put in) go around the `mod` p?
EDIT:
If I do: print(The solution `to` a^x = b (`mod ` ,p) is x = 1323)
I get:  The solution to (1235^x) = 751 (mod, 1601) is x = 1323
So is there a way to just remove the comma on the output?
Thanks.
