Question: Function "subs repeated"
I look for a maple function / or a piece of code which enable to do repeated substitutions. In other words, repeat substitutions until there is no more possible substitution.
How can I do to make repeated substitutions ?
Here a example I would like to solve with maple
Equation on which I would like to conduct variables changements:
Code:
eq := sin(psi[1](t)+gamma0(t))*cf+sin(gamma0(t)+theta[1](t)+psi[1](t))*mf-sin(gamma0(t))*hf-cos(gamma0(t))*lf+xp[1](t) = sin(psi[2](t)+gamma0(t))*cf+sin(gamma0(t)+theta[2](t)+psi[2](t))*mf-sin(gamma0(t))*hf-cos(gamma0(t))*lf+xp[2](t)
Definition of variables changement :
Code:
ChgtVariables:=psi[1](t)=Psi[1](t) - theta[1](t) + gamma[1](t),psi[2](t)=Psi[2](t) - theta[2](t) + gamma[2](t);psi[3](t)=Psi[3](t) - theta[3](t) + gamma[3](t),psi[4](t)=Psi[4](t) - theta[4](t) + gamma[4](t),theta[1](t)=Theta[1](t)+gamma[1](t),theta[2](t)=Theta[2](t)+gamma[2](t),theta[3](t)=Theta[3](t)+gamma[3](t),theta[4](t)=Theta[4](t)+gamma[4](t);
Application of subs function:
Code:
subs(ChgtVariables,eq);
The problem is that only one step of substitutions is conducted.
Here the expected result :
(sin(theta[1](t))-theta[2](t))*cf - (sin(gamma[1](t)-sin(gamma[2](t)))*mf  + xp[2](t) - xp[1](t) = 0
Thanks a lot for your hemp
