Question: Symbolic calculation of matrix rank
I would like to symbolically determine the rank of a jacobian matrix. In the help, I have seen that the Rank function of the LinearAlgebra can be used for this purpose. However, when I use this function, the function doesn't allow to find the different singularities that can occur on my jacobian matrix.
Here a exemple of a jacobian matrix that I obtain on a slidercrank mechanism:
Phi := Matrix(2, 3, {(1, 1) = -l1*sin(theta(t)), (1, 2) = -1, (1, 3) = l2*cos(beta(t)), (2, 1) = l1*cos(theta(t)), (2, 2) = 0, (2, 3) = l2*sin(beta(t))})
The rank of this jaobian (Phi) gives 2 whatever the values of theta(t) and beta(t). However, if the values of  theta(t) and beta(t) are :theta(t)=Pi/2,beta(t)=0. The rank shouldn't be 2 but 1.
Is a way to obtain the symbolic calculation of the rank of a jacobian matrix which can distinguish different cases following the values of the parameters ? In others words, my dream will be to have a Rank function (or another algorithm) which can gives :
the rank is 2 if theta(t) different of Pi/2 [Pi] and beta(t)=0 [Pi]
and otherwise 1 if ...
and perhaps 0 if ...
Thanks a lot for your help.
I let a piece of code with an example of calculation of the rank
RankMatrix.mw
