Question: Psi letter with indices
In a mechanical model, I would like to use the letter Psi. However, when I use it, i have a small issue with some index which disappear.
Here the code I put at the beginning of my worksheet to be able to use the Psi letter
constants:= ({constants} minus {Psi})[]:
`evalf/Psi`:= proc() end proc:
`evalf/constant/Psi`:= proc() end proc:
unprotect(Psi);
With the following code,
ChgtVariables:={seq(psi[i](t)=Psi[i](t)-gamma0(t),i=1..4)};
I obtain the following result:
The index with Psi has disappear.
However, if i use the code:
ChgtVariables:={seq(psi[i](t)=PSI[i](t)-gamma0(t),i=1..4)};
There is no problem of index with PSI.
Do you have a idea why the index has disappeared ? How can I do to use the Psi letter with a index ?
PS: the code associated attached here:
Psi.mw
Thank you for your help
