Question: Problem with subs command
I am unable to use subs() command when using subscript : I'd like to replace YP__1 with dGx in the equation :
"Eq:= YP__1 = Y__2" (Eq:= YP1=Y2)
 so I have tried : subs({YP__1=dGx},Eq)
But it doesn't work... It give me : YP__1 = Y__2 and I would like to have dGx = Y__2
I have tried also with subs({YP[1]=dGx},Eq) but doesn't work too.
If I am not using subscript, for exemple : Eq:= YP1 = Y2
And do : subs({YP1=dGx},Eq)
That works great...
But I must use subscript __ because Eq is a result from ODEtools (convertsys).
Can you help me please ?
Thanks you very much.
Regards.
