Question: How to convert ODE system to differential form?
how to convert system of differential equations to differential form for evalDG?
[a(t)*(diff(c(t), t))+b(t), a(t)*(diff(b(t), t))+c(t)*(diff(b(t), t)), a(t)*(diff(c(t), t))+a(t)*(diff(b(t), t))+b(t)];
when i try eliminate dt which is the denominator
eliminate([a(t)*dc(t) + b(t)*dt,a(t)*db(t)+dt*c(t)*db(t),a(t)*dc(t)+a(t)*db(t)+b(t)*dt],dt);
[{dt = -a(t)/c(t)}, {a(t)*(c(t)*dc(t)-b(t)), a(t)*(db(t)*c(t)+c(t)*dc(t)-b(t))}]
i got two solutions, which one is correct?
does it mean that two have to use together to form a differential form?
update1
with(DifferentialGeometry):
DGsetup([a,b,c], M);
X := evalDG({a*(c*D_c-b), a*(D_b*c+c*D_c-b(t))});
Flow(X,t);
Flow(X, t, ode = true);
got error when run with above result
