Question: Can't assign values from a procedure
I defined a procedure, OrderB(0,b,c), that essentially determines the order of a group that is defined by 2 parameters (the first parameter is always zero), so the output is an integer and the procedure is defined for every integer value of both parameters. I wanted to structure the outputs into a matrix with columns that represent one parameter and rows that represent the other. However, whenever I try to apply a method of defining the matrix, Maple returns the values of the procedure and then gives me an empty matrix.
>f:=proc (i, j) -> OrderB(0, i, j+3);
>Matrix(3, f);
                               1
                               4
                               1
                               1
                               4
                               1
                               1
                               4
                               1
               [NULL,NULL...]
I tried a second method where I defined a set s such that:
s:={(0,0)=OrderB(0,0,0) , (0,1)=OrderB(0,0,1).....}
but upon execution, maple returns:
1
4
1
s:={(0,0)=( ), (0,1)=( )...}
Please Help. I don't know what I'm mising in the code that is keeping Maple from putting the outputs of my procedure into the matrix.
