Question: Problem with long integrands
While performing integration of some expessions I bumped into a strange problem. My expession consists of quite a lot of terms, but here I present the susbset of only 2. If I integrate it as a whole maple does not want to solve it, and leaves it as there was no closed expression to this integral. But if I split this sum and integrate the parts, it all works fine. What is happening here? What do I miss? I used simplify and allvalues but didn't change a thing...
Is there a way to split my terms into list, integrate one by one and they recreate the solution by summing the parts? Its a bit of a workaround, but surely better that doing it manually (I have around 50 terms). I use Maple 2015
Thanks,
Jeremi
