Question: Manipulator tool - Pan a graph
I am using Maple 2015.2 on a Windows 10 machine.  I use the plot command to generate a simple graph.  I then use the Manipulator Pan tool to change the axes limits.  The system does not redraw the function with the new range limits.  The parameters in the Axis properties have been changed appropriately but the graph does not display for the new limits.  Even if I change the parameters without using Manipulator Pan tool, the system does not redraw the function with the new range limits.  Any guidance about what I am doing wrong?  I am attaching an example file in case the behavior continues on other systems.
20160711_example_of_graph_pan_issue.mw
Thanks,
Wayne
