Question: Initial value problem - dsolve does not give particular solution
Trying to solve this IVP of the SHO  (second order linear costant-coefficient).
Everything works fine until I come to the solving even after using dsolve with initial conditions (even using the differential operator D in the initial conditions)  , the answer still contains _C1, an unknown constant.
The full worksheet is below.  The code for dsolve is:
sol3 := dsolve(subs(par1, {de1, D(x)*0 = 0, x(0) = 1}), x(t));
Hoping you can help with a solution.
