Question: use both slider and textarea to control parameters with the Explore function
With the Explore function, the use of sliders is very convenient to test the sensibility of a result with regard to a parameter.
However, It is also very convenient to specify a accurate value to a parameter.
Consequently, i would like to combine the use of slider (usually defined in the default mode) with the use of the option "controller=textarea".
Do you have ideas to combine the use of slider and the use of textarea for the definition of the parameters in the Explore function ?
Here you can find a example of the theta4 function depending of 8 parameters (xp3,xp4,zp3,zp4,phi3,phi4, gamma3, gamma4).
TestExplore_4.mw
I manage to use either the sliders or the textarea option but not both.
Thank you in advance for your help and ideas.
