Question: how to fasten dsolve and is it possible to timeout faster if it know no solution earlier?
i split into near 500 blocks of nested for loop, total around 42 billions trials
i run in cmaple,
i see it run the first 4 blocks of code and output to files,  which are daff001, daff002, daff003 and daff004
it seems that it can run parallel intelligently though i write in serial lines.
but it run a very long time, still running near first 4000 records
window 10 use 3.4GB memory, only 4GB memory rest
but 4000 records use more than 4GB memory
i just hope to run 1000 records every day, hope 1000 records can be finished within a few hours
and plan to run around 500days
restart:
read "D:\\daff2039mm.m":
with(combinat):
appendto("D:\\daff001.txt");
for ii from 1 to 1 do
for jj from 1 to 1 do
for kk from 1 to 1 do
if ii < jj and jj < kk then
if mm[ii] <> mm[jj] and mm[jj] <> mm[kk] then
sol := dsolve([mm[ii] , mm[jj] , mm[kk] ],[a(t), b(t), c(t)]);
if nops([sol]) = 1 then
print([mm[ii], mm[jj], mm[kk]]);
print(sol);
print(" * **");
end if:
end if:
end if:
od:
gc();
od:
od:
restart:
with(combinat):
appendto("D:\\daff002.txt");
for kk from 1 to 1001 do
print(sol);
print(" * **");
end if:
end if:
end if:
od:
gc();
od:
od:
restart:
with(combinat):
appendto("D:\\daff003.txt");
for kk from 1001 to 2001 do
print(sol);
print(" * **");
end if:
end if:
end if:
od:
gc();
od:
od:
restart:
with(combinat):
appendto("D:\\daff004.txt");
for jj from 1 to 26 do
for kk from 2001 to 2001 do
print(sol);
print(" * **");
end if:
end if:
end if:
od:
gc();
od:
od:
restart:
with(combinat):
appendto("D:\\daff005.txt");
for jj from 26 to 51 do
print(sol);
print(" * **");
end if:
end if:
end if:
od:
gc();
od:
od:
