Question: How are units used in plots?
I tried to generate a simple plot based on an expression using units. Please see the screenshot of the worksheet below
The y-axis should be scaled in m3 not m2 because a, b and the variable r are in m. I know that it is possible to enforce the axis scaling in units using useunits but since the mathematical definition of the expression is clear this should not be necessary.
The other question is why is the y-axis missing the variable name? On this page on the Online Help http://www.maplesoft.com/support/help/Maple/view.aspx?path=MaplePortal/UnitsInPlots it is mentioned "When you plot an expression, the axes labeling shows the variable names and units." I think what I am plotting is an expression.
