Question: How to obtain the derivative value of a function obtained as a solution using pdesolve at the boundaries
I have the following code in Maple 13:
SYS := {diff(T(x, t), t) = diff(T(x, t), x, x)};
IBC := {T(1, t) = 0, T(x, 0) = 1, (D[1](T))(0, t) = -exp(t)};
SOL := pdsolve(SYS, IBC, numeric, time = t, timestep = 1/10);
R := SOL:-value(output = listprocedure); temperature := subs(R, T(x, t));
It integrates the heat equation in the interval x=0..1 and it seems to work ok.
However, I have problems trying to obtain the temperature derivative at the boundaries (this is at x=0 and x=1). I'm using different commands and it seems the derivative is evaluated ok inside the domain but not at the boundaries.
If I try
fdiff(temperature(x, t), [x], {x = 1,t=0.5});
or
evalf((D[1](temperature))(1, .5));
I don't get any numerical answer. Any idea how I could obtain the value of the derivative at the boundaries?
Thanks in advance,
Javier
