Question: Numerical Solutions to Matrix/Lattice Based Problem
Hi, so I have few problems here. I need to;
Create a MxN Matrix/Lattice, where N and M can be any positive integer, that contains a random selection of -1/1s at each entry.
Need to sum every entry, then multiply by -1 to find “H”.
Need to multiply each neighbour to find its bond energy, so if it’s the same you get 1 else -1, but only its direct neighbours once, so if it was a 2x2 matrix there would be only 4 values and then sum them.
I don’t seem to be able to set up the code so that it does it for any size matrix, as I only know how to write it out basic for a 2x2. Also, not so important, but I wanted to know if could create a loop that would find every iteration of possible setups i.e. for a 2x1 you can have 1.1, -1.1, 1.-1, -1.-1. And then give the solutions outlined earlier for each of the the possibilities [There being 2MxN ]
Cheers in advance.
