Question: PDETools Invariants Command Not Recognizing Rotations?
Hi, I'm trying to use Maple to construct some examples of symmetry solutions for certain nonlinear PDE's.  As a warm up, however, I'm working through the commands just for the heat equation in 3d: u[t]-u[x,x]-u[y,y]-u[z,z]=0
I've gotten Maple to produce both determining equations for the symmetry infinitesimal generators via the DeterminingPDE command.  I've also gotten the command Infinitesimals to work too.
However, when I next use PDETools Invariants command, it correctly outputs invariants for most of the generator output of Infinitesimals EXCEPT it won't output anything for the simple rotation generators yd[x]-xd[y].  It will, however, output invariants if the rotation is between an independent and the dependent coordinate.
An example:
with(PDETools)
S:=[_xi[x]=y, _xi[y]=-x, _eta[u]=0]
Invariants(S,u(x,y))
*Above returns nothing, But if you instead have _xi[x]=x and _xi[y]=y then it returns the right invariants.
Thanks in advance!
