Question: Erroneous 3D plot outcome.
Hi All.
I keep getting a incorrect plot of: plot3d(2*x/(x^2+y^2), x = -10 .. 10, y = -10 .. 10)
The negative range excursion is not appearing.
I have tried changing the domains and range settings but to no avail.
I have also tried placing brackets around the numerator and denominator but again to no avail. I also repeated the plot of earlier functions, on the same sheet, below the above function and had no problems with them. See the function below as an example of a good graph plot.
I noticed that the program flashes a negative value graph on screen and then only displays a positive result as shown above.
Good plot of: plot3d((-2*x^2+2*y^2)/(x^2+y^2)^2, x = -10 .. 10, y = -10 .. 10)
This example shows both the negative and positive f(x,y) values and surfaces.
Can anyone explain what is going on.
What I may be overlooking.
Is there a flaw in Maple 15?
I can get the correct graph using Microsoft Math which is a much less sophisticated program.
Omicron1
