Question: Complex algorithm giving unexpected IF problem ..
So below is a calculation im trying to create, but it just tells me there is an unexpected IF error, and returns me to the third For line. I have tried it straight and as a procedure but i just cant seem to get it to work. Any ideas or tweaks to make this work would be much appreciated. All of the other variables I've named work in their respective lines of code, which I have left out as it is long as it is!
ComlexAlgorithm:= proc(L)
local N, j, kf, o, DeltaMag, DeltaBond;
global NConfig, Configz1, Col, Row, OldConfig, NewConfig, NewTable;
# Set Delta values to zero.
DeltaMag:=0:
DeltaBond:=0:
# Creates loops to loop through the correct changes in values i.e. Add -1, then 1 to first point, move across each point one by one, repeat from the beginning for each configuration then repeat whole process for the amount of rows.
printlevel:=4:
for N from -1 to 1 by 2 do
   for j from 1 to Col do
      for w from 0 to NConfig-1 do
         for o from 1 to Row do
# Calculate DeltaMag.
if N=-1 then DeltaMag:=DeltaMag+1 else DeltaMag:=DeltaMag-1
end if:
# Calculate all relevant bonds i.e. 3 values for DeltaMag, except at "corner" lattice points where there is only 2 bonds.
if N= Configz1[w](o, j) then DeltaBond:= DeltaBond-1 else DeltaBond:= DeltaBond+1
end if:
if j-1>1 then
   if N <> Configz1[w](o, j+1) then DeltaBond:= DeltaBond+1
      if N = Configz1[w](o, j+1) then DeltaBond:= DeltaBond-1
end if:
end if:
end if:
if j+1<Col then
end if:
end if:
end if:
# Calculate if, and by what degree, conifguration number changes using 2^(j-1) which is the arithmetric series for binary. Changes only occur when "incoming" spin is different.
if N= -1 then
   if Configz1[w](o, j) <> N then NewConfig[w]:= OldConfig[w-(2^(j-1))]
else NewConfig[w]:= OldConfig[w]
end if:
end if:
if N= 1 then
   if Configz1[kf](o, j) <> N then NewConfig[w]:= OldConfig[w+(2^(j-1))]
else NewConfig[kf]:= OldConfig[w]
end if:
end if:
NewTable[kf]:= [NewConfig[w], BondEnergy(w)+DeltaBond, MagEnergy(w)+DeltaMag];
# Set Delta values to zero to finsh.
DeltaMag:=0:
DeltaBond:=0:
end do:
end do:
end do:
end do:
