Question: Plotting an unkown number of different plots in a display function
I want to have a display() function that plots a certain expression that I already have defined, but then I also want to include a variable number of pointplots into the same graph. I basically want the user to define a set of x and y coordinates into two different arrays in the start of the Maple Worksheet, then later down the worksheet, I want to plot these x,y coordinates as a pointplot, for each point.
But for example, if there are 5 points, I would define the pointplots as p1,p2,p3,p4,p5, which I already have a loop to do automatically depending on however many points that has been defined in the previous arrays. But when I want to plot these in a display() function, I have to write display(p1,p2,p3,p4,p5) individually, and I can't therefore seem to find a way to make it like display(p1,...,pn). I want the display to add more pointplots depending on how many points are defined in the arrays.
Can anyone help me? Sorry if it was difficult to understand, I can explain further if you didn't understand.
