Question: Trig simplification question, result from dsolve
The ODE diff(y(x),x) = sec(x)^2*sec(y(x))^3  can be solved as separable. So the answer should be
simple_answer:=sin(y(x))*(cos(y(x))^2+2)=C_1+3*tan(x);
as can be seen by direct integration of each side of the differential equation. I am trying to make Maple give the same answer, but not having any luck.
ode:=diff(y(x),x) = sec(x)^2*sec(y(x))^3;
sol:=dsolve(ode, y(x),implicit);
I tried simplify(sol,trig) and tried simplify(sol,size).  Both Maple answer, and the simple answer solve the ODE.
Is there a way to make Maple dsolve give the simpler answer, or simplify/convert the answer it gives to the simpler one? I am newbie in Maple.
