Question: How to use recursion in Maple
I was trying to write a procedure that would compute a simple linear equation using the Extended Euclidean Algorithm. I was thinking of a procedure like the following:
solveEeaMatrix := proc (a::list, b::list)
 local c::list;
 c := a -iquo(a[1],b[1])*b;
 print(c);
 while (c[1] <> gcd(a[1],b[1]) do
I am basically stuck at this part as
1) I don't know how to setup a multi-dimensional array that could dynamically grow(as a possible solution).
2) I can't come up with a recursive function that could possibly take care of this.
In short, if I am given for example an equation like: 84*x+203*y = 14
I will transform it into 2 linear equation as follow:
row0 := [203, 0, 1] row1 := [84, 1, 0] Subsequently, I will perform the following:
Where aand b are both lists and arguments of the procedure and cbeing another list and a local variable.
But I don't know how to do the following programmatically:
row3 := row1-iquo(row1[1], row2[1])*row2;
row4 := row2-iquo(row2[1], row3[1])*row3;
row5 := row3-iquo(row3[1], row4[1])*row4;
and so on ...
Any hint would be appreciated.
