Question: Error message: "Error, (in F) invalid input: F uses a 2nd argument, n, which is missing"
The following procedure is intended to recursively generate all vectors in the set of n dimension vectors with elements 0 to p-1. If I use a fixed value for p it works fine, but as soon as I introduced p as an argument it gives the error "Error, (in F) invalid input: F uses a 2nd argument, n, which is missing".
F:=proc(p,n)
  if n=1 then:
    return [seq(Vector([x]),x=0..(p-1))];
  else:
    return [ seq(seq(Vector([v[],xn]),v in F(n-1)),xn=0..(p-1)) ];
  end if:
F(3,2);
I cannot for the life of me figure out what is wrong with the above code? Can anyone enlighten me?
Thanks in advance for your help.
