Question: Plotting the movement of 4 planets
Greetings,
currently im working on a project in which i basically have to calcuate and plot a little solar system, using newton mechanic. The work is done, but as it appears, the solution simply cannot be true. In the given example you can see that the planets move in more or less straight lines. I presume that the error is somewhere in the solution of the system of differential equations, but i can't see where it is.
I am grateful for every advice.
PlanetenSpacecurve.mw
