Question: Help with Maple Commands
Hi I was wondering if you can help me with some maple commands about using Euler's method. My professor created a tutorial on using some commands to calculate the value via Euler's method.
Her commands in the tutorial for using Euler's method  for a differential equation- dy/dx= x+y   y(0)=1
x0:=0:y0:=1:xf:=1:n:=10:
h:=evalf((xf-x0)/n);
f:=(x,y) -> x+y
x:=x0:y:=y0:
This next step confuses me the most, my professor uses this syntax to compute the values of approximation via Euler's method. N represents the number of pieces we want to approximate the value with. X0 is initial and XF is final.
forifrom1tondo k:=f(x,y):y:=y+h*k:x:=x+h:print(x,y):od:
I tried replicating this syntax on the exact same problem, copying the syntax commands word for word. Yet, I keep getting the same error "unable to parce" error, with the "od" being highlighted. But on her tutorial, it gave her an two columns with the intervals (n) and all it's values. She even did the same did for only wanting 1 loop printed
forifrom1tondo k:=f(x,y):y:=y+h*k:x:=x+h:od:print(x,y):.   And it gave her only 1 loop.
I tried both and still got the error. Please Help, Thanks in advance
