Question: How to put the independent variable on the vertical axis
Hi!
If somebody could help me it would be awesome!
I would like to be able to switch the independent variable onto the vertical axis!
If that is not possible, what i'm trying to do is modelise in a function a set of points, but with multiple values for the same x, but not more than one for the y, so the best option would be to switch the variables, to have x dependant of y. My graphic has to be vertical though, so I can't just switch the points.
Thank you a lot
Charlotte
