Question: How do I plot four second order curves in the same figure from data available in the form of list for all coordinates?
[[1000, 20], [2000, 25], [3000, 24], [4000, 23], [5000, 24]];
data1 := [[1000, 20], [2000, 21], [3000, 32], [4000, 23], [5000, 23]]; 'data1';
                             data1
a*x^3+b*x^2+c*x+d;
                        3      2
                     a x  + b x  + c x + d
x;
                               x
Equn1 := CurveFitting[LeastSquares]([[1000, 20], [2000, 25], [3000, 24], [4000, 23], [5000, 24]], x, curve = a*x^3+b*x^2+c*x+d);
plot(Equn1,x= 1000..5000)
Least Squares Approximation
Calculate a least squares approximation using specified data points.
Theoretical Curves for the Two-Stroke Engines and Four-Stroke Engines Brake Power Vs Brake Efficiency
List of Data Points:
data1
Fitting Curve:
a*x^3+b*x^2+c*x+d
a*x^3+b*x^2+c*x+d
(3)
Independent Variable:
x
x
(4)
Least Squares Curve:
NULL
Equn1
31/5+(83/4200)*x-(23/3500000)*x^2+(1/1500000000)*x^3
(5)
Least Squares Fit of Data by a Specified Curve
[[3, -1], [5, 3], [6, -7], [7, 5], [9, -2]]
(6)
Fitting Curve:
a*x^2+b*x+c
a*x^2+b*x+c
(7)
x
x
(8)
CurveFitting[LeastSquares]([[3, -1], [5, 3], [6, -7], [7, 5], [9, -2]], x, curve = a*x^2+b*x+c)
-901/210+(213/140)*x-(11/84)*x^2
(9)
a*x^2+b*x+c
a*x^2+b*x+c
(10)
plot(sin(x), x = 0 .. 4*Pi)
Download LeastSquareApproximation_2nd_and_3rd_Order.mw
The above command plots one curve alright. I want four such curves to go in the same figure using command like
plot(Equn1,Equn2,Equn3,Equn4,view(x=1000..5000)
I am not getting by the above command what I want. Can any one help. A shortcut method is required for me to repeat many times.
Thanks for help.
Ramakrishnav V
