Question: How can I declare a the square root of a certain function is positive?
I have a problem of having a problem to solve the following equation with the this error. I found out that it might be due to that I have a differential that is squared and maple could not calculate it as after square root it will have positive and negative. May I know how to overcome this other than changing my equations?
ODE_summarize.mw
restart; with(DEtools)
sol1 := alpha*(diff(f(y), y, y, y)) = -(1/4)*f(y)*(diff(f(y), y, y))*n+(1/2)*(diff(f(y), y))^2*n-(3/4)*f(y)*(diff(f(y), y, y))+(1/2)*(diff(f(y), y))^2-g(y), diff(g(y), y, y) = -(1/4)*P[r](f(y)*(diff(g(y), y))*n-4*n*(diff(f(y), y))*g(y)+3*f(y)*(diff(g(y), y)))
alpha*(diff(diff(diff(f(y), y), y), y)) = -(1/4)*f(y)*(diff(diff(f(y), y), y))*n+(1/2)*(diff(f(y), y))^2*n-(3/4)*f(y)*(diff(diff(f(y), y), y))+(1/2)*(diff(f(y), y))^2-g(y), diff(diff(g(y), y), y) = -(1/4)*P[r](f(y)*(diff(g(y), y))*n-4*n*(diff(f(y), y))*g(y)+3*f(y)*(diff(g(y), y)))
bc := (D(f))(y)
(D(f))(y)
gg := convert(bc, diff)
diff(f(y), y)
(3)
gg1 := limit(gg, y = infinity)
limit(diff(f(y), y), y = infinity)
(4)
gg2 := convert(gg1, D) = 0
limit((D(f))(y), y = infinity) = 0
(5)
gg2
(D(f))(y) = 0
(6)
bc1 := eval(f(y), y = 0) = 0, eval((D(f))(y), y = 0) = 0, convert(gg1, D) = 0, limit(g(y), y = infinity) = 0, eval(g(y), y = 0) = 1
f(0) = 0, (D(f))(0) = 0, limit((D(f))(y), y = infinity) = 0, limit(g(y), y = infinity) = 0, g(0) = 1
(7)
odesub1 := eval(eval(sol1, n = .6), P[r] = 0)
alpha*(diff(diff(diff(f(y), y), y), y)) = -.9000000000*f(y)*(diff(diff(f(y), y), y))+.8000000000*(diff(f(y), y))^2-g(y), diff(diff(g(y), y), y) = 0
(8)
sol2 := dsolve({bc1, odesub1}, numeric, [f(y), g(y)], output = operator, continuation = alpha, initmesh = 2400, method = bvp[midrich])
Error, (in dsolve/numeric/bvp/convertsys) unable to convert to an explicit first-order system
