Question: issue with fsolve and Directsearch command in maple
I have three simultaneous equations  with three unknown variables (E, W, T). When I solve these  simultaneous equations with fsolve command without specifying any range for variables, I don't get desirable root ( equation sol4 in maple worksheet- {E = 0.1007672475e-2, T = .7969434549, W = 0.1937272759e-2}). For this problem, I know the correct root {E = 2843.916504, T = .2782913990, W = 5344.844134} beforehand which maximize the objective function TP (equation sol8 in maple worksheet) and when I specify the narrow range of variables around the already known correct root in the fsolve command, then I get correct root ( equation sol5 in maple worksheet). If I don't know the actual answer (correct roots of the simultaneous equation) beforehand, How  could I get the correct root with fsolve command because it is very tedious work to specify different range in fsolve command repetitively to solve it by trial and error.
I also tried Direct Search method as suggested in this forum  but DirectSearch is also not able to provide the correct root (equation sol6 in maple worksheet). If I specify the narrow range around known root in direct search method ( equation sol6a in maple worksheet), then it would provide close to optimal root but if I don't know the correct root beforehand, then I couldn't specify the narrow range of variables, then how can I get correct root through direct search command.
Equation sol10 in maple worksheet  (objective function value at correct root) confirms that {E = 2843.916504, T = .2782913990, W = 5344.844134} is the correct root because it provide the value of objective function (TP) equal to 78285.85621 as opposed to negative value (TP value -12.53348074 in equation sol9)  produced by incorrect root  {E = 0.1007672475e-2, T = .7969434549, W = 0.1937272759e-2}).
Is there any method which would provide all the roots of these simultaneous equations which also include correct root. Maple worksheet is attached.
I am trying fsolve and direct search method with known root so that I could get the proper procedure to get the correct root which I can apply to another problem (set of similar simultaneous equations) for which I don't know correct root beforehand.
Thanks for your anticipated help.fsolve_question.mw
