Question: How to simplify this solution?
sol:=dsolve(diff(y(x),x)= x/(sqrt(x^2-16))*1/(2*y(x)),y(x));
Gives
But the solution can also be written as
I just do not know how to transform the first solution to the second simpler one. I tried:
sol:=map(x->rhs(x),[sol]);
simplify(sol,radical);
Also tried simplify(sol,sqrt); simplify(sol,radical,symbolic); simplify(sol,size);
The simpler solution can be found as follows
sol:=dsolve(diff(y(x),x)= x/(sqrt(x^2-16))*1/(2*y(x)),y(x),'implicit');
But the term in the middle above is
Therefore the solution is really
eq:=y(x)^2-sqrt(x^2-16)-_C1 = 0;
solve(eq,y(x));
Which gives
What command to simplify the long solution to the shorter one obtained from the implicit?
