Question: Can a minimum value for the launch velocity and its related launch angle be found?
The following procedure describes the path of a projectile fired from the origin with a launch angle of alpha and a launch velocity of u.
z := proc (x) options operator, arrow; tan(alpha)*x-(1/2)*g*x^2/(u^2*cos(alpha)^2) end proc
The projectile's path must pass through the point [a, h], both values greater than zero.
Can an expression be found for the minimum value of u and its related value for alpha?
