Question: interrupting solve command
I am having a difficulty is running a loop with solve command. I am using a command solve(f(x,alpha)=0, x) in a loop for alpha = 1 by 1 to 10. For some reasons, for some values of alpha, the solve command does not give any solution and hence the program keeps running on. When I interrupt the program at such instance, the remainder of the program is not complete.
I tried using the try-catch command. I face the same issue.
Is there a way for me to bypass the solve command when it does not find any solution for a particular alpha and continue with the remainder of the program? I can come back and manually obtain the solution for such alpha values where solve command does not provide an answer.
I would appreciate your help.
Regards,
Omkar
