Question: Inverse laplace transform using factor in Maple 18
Dear Maple users,
I have a big exporession in the form f(s)/g(s) where f and g are polynomial involving irrational coefficients. Both f and g consist of hundreds of terms. One way to get the inverse laplace is to factor the expression and then take the invlaplace.
The code is as follows:
with(inttrans):
p:=factor(f(s)/g(s));
sol:=invlaplace(p,s,t);
I get sol as a function of time, which gives satisfactory result for t=0 but  grows bigger and bigger with increasing value of time. From the limit theorum I see that  Limit (s*f(s)/g(s)) as s--> 0 is finite, which means that the invlaplace is not correct at very large value of time.
What is the error in the process?
Thanks,
