Question: Plotting range as procedure parameter.
Hey everyone
I am trying to create a procedure, which includes a part, where a function is plotted. I want to be able to declare the range of the plot within the procedure parameters as x=range - example when executing: procedureName(function,x=range). I have isolated a small part of the procedure and the different approaches I have tried:
For simplicity's sake let's call the procedure test.
test:=proc(function,{x::range:=0..1})
#I would then like to be able to plot the following:
plot(function,'x'=x);
However, the single quotes do not prevent x from being evaluated within the procedure, and there interprets the second argument of 'plot' as 0..1=0..1. Another approach I tried was the following:
local xRange:=x;
unassign('x');
plot(function,x=xRange);
However, I run into the same problem as above - the elements within the single quotes are still evaluted within the procedure. A workaround would be to simply rename the range parameter, for example:
test:=proc(function,{xInr::range:=0..1})
plot(function,x=xInr);
I would really like to be able use x as the parameter, though.
Thanks in advance!
