Question: open source code for RootFinding[Isolate] command
I have a code in Maple that solves a system of polynomial equations (18 equations, 18 variables) using the command 'RootFinding[Isolate]' (it takes to Maple about 40 minutes to find all the solutions to the equations). Is it possible to see the implementation of the Isolate command? if not, is there any other open source code that implements the equivalent to Isolate command and also able to solve such equations? (I'm talking about the  numeric solutions. not symbolic).
I already tried to use the command 'solve_poly_system' in python (sympy package) which is open source. but the function didn't return a solution after a very long time (and I used a system of 9 equations and 9 variables which were much simpler than the equations Maple was able to solve using Isolate command).
I'm attaching the equations Maple solved using Isolate command. and also the equivalent in python with the simpler equations (that it wasn't able to solve).
solving_18_polynomial_equations.mw
trying_to_solve_polynomial_equations_python.txt
I'd appreciate any idea of how to use open source code that produces the same results as the code in Maple (if it's possible).
Thanks
