Question: Trying to draw a sequence of triangles for animation
Am trying to draw a series of triangles for animation.  I try to construct the triangles in a loop using:
triangle(cat(T1,`a`),[A,B,C]):
  so that the names of the triangles are meant to beT14, T15, T16
I have tried unsuccessfully to use the plots and draw commands ie
draw({seq(tabl[i], i=4..6)}, insequence=true, scaling=constrained);
plots[display({seq(tabl[i], i=4..6)}, insequence=true, scaling=constrained);
  Can the animation be done in either?
It seems to want a variable in a list/set format - How do I set that up?  Any comments, or help gratefully received.  The program is below.  Part of the output does give triangles - but they all seem identical:-(
restart:
# Altitude exploration  program
#Trying to draw a sequence of triangles for animation
with(plots):
with(geometry):
for a from 4 to 6 do
b:=a+1: c:=a+2:
angA:=arccos((a+5)/2/(a+2));
point(A,0,0),point(B,c*cos(angA),c*sin(angA)),point(C,a+1,0):
tabl[a]:=triangle(cat(T1,`a`),[A,B,C]):
printf("a=%d\n",a);
end do:
for i from 4 to 6 do
draw({seq(tabl[i], i=4..6)}, scaling=constrained);
printf("a=%d\n",i);
print(`After do`);
Warning, the name changecoords has been redefined
Warning, the name arrow has been redefined
Warning, these names have been redefined: circle, ellipse, homothety, hyperbola, line, point
a=4
a=5
a=6
a=4
a=5
a=6
