Question: how to write multiline string to a file?
I want to save multiline string to a file. I am not sure Maple likes my string. Also when I look at the textfile after writing the string to it, the string does not look like what is expected. I given small example
First, created a "proc.mpl" in the folder. Here is the content of "proc.mpl"
process_file := proc()
local str;
str:="
   \\begin{align*}
     A =& B \\\\
       =& 3
   \\end{align*}
FileTools[Text][WriteString]("output.txt", str);
FileTools[Text][Close]("output.txt");
Then opened Maple, and from a worksheet, called the above proc() like this
currentdir("C:\\where_the_file_is");
read("proc.mpl");
Warning, incomplete string;  use " to end the string
process_file();
You see these warnings there. So how does one make a multiline string in Maple? Please tell me it is possible. Else this whole process will not work.
When I look at the "output.txt", where the string is written, this is what shows
   \begin{align*}
     A =& B \      =& 3
   \end{align*}
Which is wrong, I expected this
   \begin{align*}
     A =& B \\
        =& 3
   \end{align*}
I use \ to escape each \, since this is Latex code.
QUestions are:
1) Can one have multiline string in Maple? as in
line one
line two
With implied carriage return, just as it appears in the input?  I do this all the time in Mathematica.
2) Is something wrong with how I am saving the string to the file?
On a side note: I noticed I had to close the textfile to see the output in it. It looks like FileTools[Text][WriteString] does not flush the string autmatically to a otuput file after each write() which is a little annoying.
Using Maple 2017.3 on windows.
This is how the above is done in Mathematica
And this is "test.txt" which shows the output as expected
   \begin{align*}
     A =& B \\
       =& 3
   \end{align*}
I'd like to do the same in Maple.
