Question: why warning Warning, incomplete string; use " to end the string shows up using read(mpl) only?
I have a function inside a file called proc2.mpl
When I read the file from a worksheet using the command read("proc2.mpl"); I see warning messages
printed on the screen.  Now if I copy the same exact code and past it into the worksheet and invoke the function, I see no warning messages.
Why is that? Here is the content of "proc2.mpl"
process_file := proc()
  local str,fileName;
  fileName := "output.txt";
  str:="
   \\begin{align*}
     A =& B  \\\\
       =& 3
   \\end{align*}
  writebytes(fileName, str);
  close(fileName);
Here is screen shot loading the function from worksheet
But now when I call it using process_file(); it works as expected.
Now here is screen shot with same code inside the worksheet itself. No warning messages show up when I call it.
And the above call also works as expected.
So I am now ignoring these warning messages since I also do not know what causes them.
Any ideas why they show up when the code is inside a .mpl file and not in the work sheet?
Maple 2017.3 on windows.
