Question: Substituing an entire matrix (or vector/array)
Hello everybody
I am currently having trouble 'manually simplifying' an equation that I differentiated using maple. Basically, the equation that I get involves hessian-matrices. Since the resulting equation is rather long, I would like to replace every such matrix by a sign, say H.
This is easy to do for non-matrix equations, i.e.
subs(sin(x)sin(y) = z, sin(x)sin(y) + xy)
will give me z + xy, which looks a bit easier.
However, I couldn't figure out how to do a similar thing with matrices. For example, the following code
subs(Matrix(3, 3, [[x, y, z], [y, z, x], [z, x, y]]) = A, Matrix(3, 3, [[x, y, z], [y, z, x], [z, x, y]])+B)
 will not work.
I already thought about converting the matrices first into lists (because for some reason it works for lists). However, I would also like to do the same as above for for functions of matrices, i.e. set F(A) = G, where A is a matrix (this also fails, probably for the same reason).
Also, the same thing seems to fail for vectors and general arrays, so I guess the actual problem might be the array type.
I also tried alternative ways, such as eval or algsubs, but the later even gives an error since it cannot handle matrices at all.
This feels a bit like a noob question, but I spent almost 2 days now searching for an answer or a workaround, so my apologies if I missed something trivial.
All the best
Adrian
