Question: why Maple mserver.exe hangs on this convert() call?
This is on Maple 2017.3 under windows
After obtaining solution from pdsolve(), I tried to see if Maple can convert it to hyperbolic trig functions by calling `convert(sol,trigh)`.
I waited and waited and nothing happened. Then clicked on the `interrupt current operation` button at top of menu.
But I found that mserver.exe has hanged in a loop. Taking 100% CPU and still running. So Had to terminate it from task manager.
Question is: It is ok if Maple can't do the conversion, but why does it hang? Maybe if I want for one hr it will finish, I do not know. But the important part, why does `interrupt current operation` does not work, in the sense that the mserver.exe is still running?
Is this common thing to happen? Should this be fixed?
Here is example
interface(showassumed=0);
pde:=diff(u(x,y),x$2)+diff(u(x,y),y$2)=0;
f:=x-> piecewise(x>0 and x<1/2, 2*x, x>1/2 and x<1, 2-2*x);
bc:=u(0,y)=0,u(1,y)=0,u(x,0)=f(x),u(x,2)=f(x);
sol:=pdsolve([pde,bc],u(x,y)) assuming x>0,y>0;
The above works OK and generates a solution. Now the next call hangs mserver.exe
convert(sol,trigh);
In case your Maple version can't solve the above PDE. Here is the solution obtained, so you can try this below without having to solve the PDE
sol := u(x, y) = Sum(8*sin((1/2)*n*Pi)*sin(Pi*x*n)*(exp(Pi*n*(3*y-2))-
         exp(Pi*n*(3*y-4))+exp(Pi*y*n)-exp(Pi*n*(y-2)))*exp(-2*Pi*n*(y-2))/(Pi^2*n^2*(exp(4*n*Pi)-1)),
            n = 0 .. infinity);
convert(sol,trigh);
I also tried convert(rhs(sol),trigh); but it made no difference.
