Question: basic question on use of private proc inside module
I am learning to use module().  If one has a local private proc() inside  a module, then on calling this local proc from inside the module itself, does one need to call it using module_name:-local_proc() or is it safe  to just call it using local_proc()?
i.e. will Maple always look to resolve this name inside the module first, before looking outside? What order Maple uses to resolve names?
Here is an example
private_proc:= proc()
    print("Opps, should not be calling this, global copy");
foo :=module()
    local private_proc;
    export public_proc;
    private_proc:=proc()
        print("inside private");
   public_proc:= proc()
        private_proc(); #will this always call foo:-private_proc() and not
                        #any other global proc with that name?
end module;
foo:-public_proc();
gives "inside private". So it seems to work without having to use foo:-private_proc(). But I thought to ask if the above will always work like this.
