Question: Maple procedure doesnt give answer
Bisection := proc (f, a, b, delta)
local startpoint, endpoint, midpoint; startpoint := a; endpoint := b;
do midpoint := (1/2)*startpoint+(1/2)*endpoint;
if abs(startpoint-endpoint) < delta or abs(f(midpoint)) < delta then
return midpoint
elif f(midpoint) < 0 then endpoint := midpoint
elif 0 < f(midpoint) then startpoint := midpoint
end if end do end proc
I'm trying to do a procedure for bisection method but it doesnt give me answer when  I type
Bisection (x-> x + 0.001 , 1, -1, 0.001 )
it returns Bisection (x-> x + 0.001 , 1, -1, 0.001 )
why this is happening, Is it because the procedure is wrong ? or does not provide answer
