Question: odetest failes to verify solution when changing _C1 to C1
I found that when changing constant of integration from _C1 to C1, Maple now fails to verify solution.
Is one supposed to only use constant with _ in it for this? I prefer to use C1 instead of _C1. Why does Maple odetest fail in this case? Is there a way around this?
Here is an example
ode:=diff(y(x),x)=x*ln(y(x)):
implicit_sol := -Ei(1, -ln(y(x)))+C1=(1/2)*x^2;
explicit_sol := solve(implicit_sol,y(x)):
odetest(y(x)=explicit_sol,ode);
Now changing C1 to _C1 and nothing else, odetest verifies the solution
implicit_sol:= subs(C1=_C1,implicit_sol);
I understand the using symbol with _ is a convention in Maple for global symbols. But I want to use C1 and not _C1 as it is easier to read.
