Question: how to tell Maple not to change expression when using abs() on it?
I want z  to becomes abs(z) then later on, remove abs() and obtain z back in the same form it was.
I found that Maple changes z when I put it inside abs. Like this
expr:=(-y^2+1);
abs(expr);
op(1,%);
So instead of 1-y^2, I end up now with  y^2-1. I want to keep the same expression I started with.
Mathematica does not do this:
expr = 1 - y^2
Abs[expr]
%[[1]]
Is there a way or option to tell Maple not change the expression when I put it inside abs()?
This complicates what I am trying to do in Maple.
thank you
