Question: Why is surrounding proc local variable not global to an inner proc?
From help it says
"For any variable used within a procedure without being explicitly
mentioned in a local localSequence; or global globalSequence; the
following rules are used to determine whether it is local or global:
The variable is searched for amongst the locals and globals (explicit or implicit)
in surrounding procedures
, starting with the innermost.  If the name is
encountered as a parameter, local variable, or global variable of such
a surrounding procedure, that is what it refers to."
So it seems if I do not use explicit "global" on a variable, Maple can figure
if it is global or not using the above rules. But when I use explicit "global"
on a variable, Maple did not seem to do the same thing. Here is an example
foo:=proc()
  local a, inner_proc;
  inner_proc := proc()
     local b;
     b   := ithprime(10);
     a   := b; #this assiged the global (to this proc)
               #variable, which is "a" correctly
  inner_proc();
  return(a);
calling foo() gives 29.
But since the variable "a" in foo() is a global with respect to the inner_proc() (based on what the above help page seems to say), then why this does not work
foo:=proc()
     local b;
     global a;
     b   := ithprime(10);
     a   := b;
  inner_proc();
  return(a);
Now foo() returns "a". So Maple did not assign 29 to the global "a", (global to the inner_proc).
This for me makes little sense. Is global in Maple means the outermost scope only, skipping everything in between?
I thought global means any variable outside the proc itself. So if the proc() was inside another proc(), then the variables in the outer proc are global to the inner proc, even if they are declared local to the outer proc.
Why did Maple not do the assignment when I explicitly declare "a" to be global in the inner proc?
