Question: Error, (in dsolve/numeric/bvp/convertsys) unable to convert to an explicit first-order system
how i can dsolve this equations and  convert the equations to an explicit first-order system ?
Also parameter 'p' is unknown and shoud be found.
error2.mw
restart
with(PDEtools, casesplit, declare);L:=0.75e-4:
[casesplit, declare]
eq1:=0.2079268293e-3*(diff(psi(x), x, x))-101.2059621*(diff(u(x), x, x))-101.2059621*(diff(w(x), x))*(diff(w(x), x, x));
eq2:=0.2079248162e-3+29.57317072*psi(x)-29.57317072*(diff(w(x), x))-1.996189024*10^(-9)*(diff(psi(x), x, x))-1.996189024*10^(-9)*(diff(w(x), x, x, x));
eq3:=151.8089432*(diff(w(x), x))^2*(diff(w(x), x, x))+101.2059621*(diff(u(x), x, x))*(diff(w(x), x))+101.2059621*(diff(u(x), x))*(diff(w(x), x, x))-0.2079268293e-3*(diff(psi(x), x, x))*(diff(w(x), x))-0.2079268293e-3*(diff(w(x), x, x))*(diff(psi(x), x))+29.57317070*(diff(w(x), x, x))-29.57317072*(diff(psi(x), x))-1.996189024*10^(-9)*(diff(psi(x), x, x, x))-1.996189024*10^(-9)*(diff(w(x), x, x, x, x))-p*(diff(w(x), x, x));
0.2079268293e-3*(diff(diff(psi(x), x), x))-101.2059621*(diff(diff(u(x), x), x))-101.2059621*(diff(w(x), x))*(diff(diff(w(x), x), x))
0.2079248162e-3+29.57317072*psi(x)-29.57317072*(diff(w(x), x))-0.1996189024e-8*(diff(diff(psi(x), x), x))-0.1996189024e-8*(diff(diff(diff(w(x), x), x), x))
151.8089432*(diff(w(x), x))^2*(diff(diff(w(x), x), x))+101.2059621*(diff(diff(u(x), x), x))*(diff(w(x), x))+101.2059621*(diff(u(x), x))*(diff(diff(w(x), x), x))-0.2079268293e-3*(diff(diff(psi(x), x), x))*(diff(w(x), x))-0.2079268293e-3*(diff(diff(w(x), x), x))*(diff(psi(x), x))+29.57317070*(diff(diff(w(x), x), x))-29.57317072*(diff(psi(x), x))-0.1996189024e-8*(diff(diff(diff(psi(x), x), x), x))-0.1996189024e-8*(diff(diff(diff(diff(w(x), x), x), x), x))-p*(diff(diff(w(x), x), x))
dsys3 := {eq1, eq2, eq3, psi(0) = 0, psi(L) = 0, u(0) = 0, u(L) = 0, w(0) = 0, w(L) = 0, ((D@@1)(psi))(0) = 0, ((D@@1)(w))(0) = 0, ((D@@1)(w))(L) = 0}; dsol5 := dsolve(dsys3, 'maxmesh' = 1200, numeric, abserr = .1, output = array([L]))
L
0.75e-4
(3)
Download error2.mw
