Question: Re-running Maple Code to solve differential equations gives different results.
Hi, I'm quite a beginner in Maple.
Currently, I'm solving several complex ODE using maple. When I run the code, it gives me some results. However, when I re-run the code using exactly the same equations and parameter, I somehow got completely different results. Using the same input sometimes it gives float(undefined), complex number, or real number.
Could anyone explain what's happening here? Does it mean that my set of ODE is not independent of each other?
Any helps would be greatly appreciated.
Thanks!
